r5g Active member Joined Sep 26, 2005 Messages 3,833 Reaction score 14 Location Nevada Rating - 100% 199 0 0 Nov 22, 2010 #1 low to moderate burn 19" wg 7000 tube pix avail $60 plus 39 ship 99 total for games like paperboy, apb, super sprint ect
Black Matrix Well-known member VAPS Joined Dec 21, 2006 Messages 3,290 Reaction score 35 Location Greeneville, Tennessee Rating - 100% 5 0 0 Nov 22, 2010 #2 I wonder if it would fit a WG K6100. It would be cool if it did since it would upgrade it to a Med Res with a yoke swap.
chris25810 Well-known member VAPS Joined Oct 3, 2006 Messages 7,103 Reaction score 68 Location lake elmo, Minnesota Rating - 100% 178 0 0 Nov 22, 2010 #3 Black Matrix said: I wonder if it would fit a WG K6100. It would be cool if it did since it would upgrade it to a Med Res with a yoke swap. Click to expand... Negative on the 6100 fit, the pin config is completely different on the end of the tube
tester007 Well-known member VAPS Joined Jan 14, 2007 Messages 2,609 Reaction score 43 Location Calgary, Alberta, Canada Rating - 100% 15 0 0 Nov 22, 2010 #4 the pin config would be the same, but its a 90 degree tube so won't work in a 6100. It will however work in an amplifone vector setup because its the same crt as that, an M49Awoox.
