What is the best way to remove the CRT and chassis from a Medalist Dart Start machine? Should I remove the top section that is bolted to the base, then remove the CRT assembly?
Yes. Break it down first. It's way easier to access the CRT. Just remove the entire monitor with the frame as one unit - it's much easier to disassemble once it's out of the cabinet.
