paul400
have a chance topick up a couple med res monitors. what are they going for these days?
$230 shipped for a 25" medium res on ebay
http://cgi.ebay.com/NEOTEC-25E-25-I...247?pt=LH_DefaultDomain_0&hash=item1c1a60a39f
so i'd say alot less for a smaller size and even less for APB burn.
I'm currently going the way of a CGA to VGA converter using a 21" (20" viewable) VGA CRT monitor. The medium res -> vga is not that big of leap than say CGA to VGA so it does not look that bad.
$40 for converter & ~$40 21" monitor on craigslist = DONE
I would not say that a 19" med res is worth less than a 25". Quite the contrary. 25" med res are still plentiful, 19" are scarce. They were really only used in Paperboy, APB, and Championship Sprint. There were many newer games that used 25" med-res.
I would say a K4915 would be worth 150.00 for just a nicely working, capped chassis.
I'm looking at doing this for my Championship Sprint. Post a thread with many pictures and all of the problems you run into so that I can learn from them and not repeat them.![]()
Well I'd let my 19" med res monitor go for $150 including the no burn tube and recently capped chassis
i found a mid res 19in in a trashed toobin a few weeks ago
Yeah, there's a handful of games that use a 19" medium resolution monitor....besides the 3 or 4 mentioned.....Super Sprint, Narc, and Escape From The Planet Of The Robot Monsters also come to mind.
Edward
FYI, a standard res tube was used on the majority of medium res 4900 monitors 19VMKP22. The chassis and yoke determine the resolution.
I will be making tubes available in the next few weeks.
Tis true. My APB has wicked 1941 burn in.
