Measuring resistors and transistors on the AR2 Boards R6, R7, R29, R30 & 2N3055?
How do I measuring resistors and transistors on the pole position ar2 boards. These seem to be the likely suspects on all the ar2 boards.
R6= 3.9k 1/4 watt resistor
R7 7.5k, 1/4 watt resistor
R29 10 ohm, 1/4 watt resistor
R30 10 ohm, 1/4 watt resistor
2N3055 Transistor, TO-3 Package
1) What would I set my dmm at to measure the resistors on those AR2 boards? Would 20k ohms be correct?
2) Should resistors be out of circuit when testing these ar2's?
3) How do I test a 2n3055 Transistor?
Thanks for your time I am almost there...
