Me needs edumication
adams_arcade
Donor 2012, 2023
Ms Pac Man original Midway door ....
What size screws to attach to the cabinet (door only)
ummm
The coin door frame is attached to the front of the cabinet with studs on the frame and nuts attaching them from the inside of the cab.
The door itself is attached to the frame via the hinge with three small screws.
Size? Who knows?
I see. They are the same as on the four corners on the CPO, so if you find those or want to use them there instead, they will fit. I always found those silly anyways.
Yes...The door itself is attached to the frame via the hinge with three small screws.
I need those screws the cab i have came gutted the frame is still installed but have not found the right screw for hinge to frame
Sweet to Lowes I go tomorrow Thanks!
LOL 1.95 for 4 screws .......plus shipping
ArcadeShop has the same ones for less, $5 shipped IIRC. I don't think any hardware stored have screws that small.
local ace hardware or mom and pops hardware store should have these.
6-32's are a very common size. If your local HW stores don't carry them, they suck beyond belief. Too long screws can easily be cut down to the needed length, as well. Lowes should have em though.
