MCR Switcher Adapter
wickedbass
Massachusetts
Where is the best place to get these? assuming they are all the same manufacturer(not sure) what is the cheapest?
-Thanks
or anyone have one for sale ?pm me
the arcadeshop one is $79 including a switcher. wizzesworkshop has just the adapter for $45, which is pretty cheap assuming you have a switcher.
Just don't put one in a Spy Hunter...
oops, totally forgot about mark's, which i've heard is better. i'm not real familiar with atx power supplies though. do they have the connector on them which basically plugs into the adapter, or does it have to be wired in. (having trouble searching for the thread when you first made them.)
Mine have the 20-pin ATX connector, just like a computer motherboard... plug that in, plug the 2 15-pin amps in, and wire power to the input of the ATX and you're done...
You can put one in a Spy Hunter if you use an alternate amplifier, but don't forget the 1.2K resistor missing for the tilt / reset circuit...
SH
Yes, where is this ATX version? And did they have the sense to put a proper reset circuit in it (with the 1.2K ohm resistor)?
Yeah, if you know what you're doing, it's cheaper and better to fix the PS yourself, components are pretty cheap.
SH
The ATX is mine, and of course it has a proper reset circuit.
I don't currently have any built up, so I can't post pics, but I plan to order parts and get those going again soon.
If you think the components are cheap, you better hope your LM305s aren't blown.
