I have a Spy Hunter upright. Originally the music was not playing and I have done the usual stuff to get that working well:
Recapped and re-socketed the cheap squeak
Cleaned the various connectors
removed corrosion from all the ground straps and actually tightened the nuts
The music started working right away.
I tried to adjust the +5 voltage but at the maximum of the pot setting it's not quite good enough. The voltage of the CS board is still low though: 3.7x volt-ish
I ordered the 2 big caps from Bob Roberts the 55,000 25v and the 100,000 16v. Bob sent me a 56,000 25v cap? What's the correct part??? Bob is not responding after 2 days which is not his normal style.
Also if you have a picture of the bottom of the PS chassis that would be nice. thanks
