tec9
Hey all-
I've got a 4 player Demolition Derby that is giving me problems. I am having issues with the cars steering. All of the cars intermittently steer just a little by themselves. They just change their angle just a bit here and there. It seems to happen alot more when you have 3-4 players. When I go into test mode, the wheels appear to function correctly. However when in test mode, if you press the start buttons quickly, the value/position of a random car might flash for a second to a different value, but go right back to the orignal number. Anybody have a working 4 player Demolition Derby that can check this in their test mode?
Here is what I have done-
-Swapped out the main PCB stack
-Swapped out the power supply (tried different voltages on the +5V and +12V)
-Swapped out the steering opto PCB's ( I have 2 spares I tried putting in all different locations)
-Swapped out the main transformer assembly
-Swapped out IC's on the SSIO for the inputs- 74LS244 and 74LS273
-Checked out all the wiring on the cabinet. I actually checked continuity from the components on one PCB to another PCB (eliminating the chance of putting pressure on a failing connector and getting a false reading) I even jiggled the harness on every pin.
After all that....the problem still exists. Can ANYBODY offer any help or suggestions?
-Mark
-Mark
