Rockolaman
I have a Rowe CD-100B with a wiring issue with the pinout of the plug which goes to P7 on the MCC (in book ref as P12).
I've searched these forums looking for anyone who has posted a picture of the 17pin plug on the bottom of the MCC. I was looking for a pic that clearly showed the wire color pinout.
It might be that the used CD-100B I purchased had the entire mech swapped at one point or from the factory the wire color codes do not match the CD-100B vol1 & 2 manual.
In any case getting a little ahead, I stupidly (but carefully) removed each wire to regap and clean the contacts. I walked away from it for a few days and now cannot make heads based on reading the schematic, which wire color corresponds to the number pin. In particular the wires to the inner & outer cams, the three black wires, and the white orange wire.
In short the wires I'm stumped on are the common black wires from the "transfer, magazine, & detent" which show just one wire going to pin 7. What pins do the other two black wires coorespond to? Same question for the inner/outer cam white orange wires.
The block diagram only shows one wire going to pin 15.
So question is, can anyone post the pinout or past a picture in reply of yours?
ANY assistance with this would be greatly appreciated!
Norm
Norm
