MC Restore Power and AR wiring help needed!
neopolss
Donor 6 years: 2013, 2016-2020
Topeka, Kansas
I've got all of the parts I need and I'm putting this beast together now. I am finding out though that there is very little *written* info and what goes where. Specifically, I need to know the pinouts of the ARII so I can verify what I am missing. I have *most* of the wiring, but I know that there's a few spots I will need to make connectors for that are lost and/or cut. Specifically, I'm having trouble knowing what connects to what on the power brick, and how the AC power connects to the ARII. I'm pretty sure that's where I'm missing the bulk of my wiring, since I can easily make out the CP connectors, monitor, marquee, sound. Any help is appreciated. A photo of your inner cab even better.
Ok. I've found a diagram of the wiring for the cab. So now I know what I am missing. So now I do need some help. I'm missing the connector that goes into the power supply. It's a 12 pin, I'm guessing .084? Anyone know for sure? From there it looks like I'll need to make a harness to fit into a 15 pin, which I do have, that then goes into the ARII. I noticed though that all the pins for the ARII are not present on the connector. Is there some voltages from the PS that aren't really used?
Anyway, the next part is a 24 pin connector that hooks up to the coin door stuff. It's black. I'm missing the side on the door that was cut. Does anyone know who makes these? I think if I can nail the specifics on the connectors so that I can order the right parts, I should be all set.
The 12 and 15 pin connectors are .093 Molex. The 24 pin is .062 amp. Don't recall if the .062 molex will fit it or not.
any idea who might sell a .062? The others are pretty standard.
I guess I don't know molex sizes very well. I thought .084 were a fairly large size?
