maximum force sync issues- nt-25
pinnut
New York
maximum force, had a dead monitor,neotec nt-35 . regulator IC replaced, and monitor powers up. works very well with TPG and neg horz sync. nice images, rock steady. however, with the game plugged into the monitor , its another story. both horz and vert refuse to hold steady, no matter how much you try to adjust it out. i also tried to adj the horz on the chassis itself, no help. B+ is good. because it rolls in both directions, when you get it as close as you can, the image seems to move diagonally. see pic
the game plug has RGB, ground , and 2 sync wires, vert and horz? it worked well with just the neg horz sync from TPG.
any idea what to do next? it tough to work on , the back cabinet doesnt come off, you work thru a small hole. its a pain
video here: https://youtu.be/ATev2Mi1BjM
thanks
