bolex
This is last call for this game that I've had posted here for several weeks. Will part out in 2 weeks.
The game is complete, monitor works, sound works, PCB boots just fine.
The game does need some work and troubleshooting:
1. The molex connector to the PCB needs to be replaced (I'm surprised it works right now to tell you the truth).
2. The steering wheels needs troubleshooting: The Reflective sensors on the steering wheels are powering up but not reading anything according to the test screen. The reflective sensors to the accelerators work fine, so I'm not sure what's going on. (both the pedals and the steering wheel connect to the same sensor control board). I've purchased a few new reflective sensors that I'll throw in.
3. The shifter on the left player does not lock onto any of the gears. There's a metal guide inside that needs to be replaced or a new one created. It also reads only 3 and 4th gears in the test screen.
4. The monitor works and in a dark room it looks just fine. It's a little weak though and there is some burn in. The tube on the G07 should eventually be replaced.
5. Cabinet needs some work. It could use some TLC.
Here are a few more pictures: https://picasaweb.google.com/112732...authkey=Gv1sRgCJDU0c_9vsDGzAE&feat=directlink
