Maverick steamboat ball entrance
sundodger
Balla, Mayo, Ireland
My Maverick's steamboat ball entrance triggers itself constantly after about half an hours playtime. it is perfect up to that point.
If i power off for a while it is fine again.
Any suggestions? has anyone seen this fault before?
I just fixed this same problem. Clean the optics on the wheel entrance and check the relay under the playfield for bad solder joints.
Oregonarcade it seems you are spot on, did as described and had the machine on and playing for an hour or so and no problem.
Thanks For the help.
