My asteroids machine is exhibiting some issues and thought I would put them all in one thread.
1. Some characters are not being drawn properly. There appears to be some 'pixels' shifted in the vertical direction, but only along the centerish of the screen. (See images where digit 2 is impacted). Need to recheck test crosshatch pattern.
2. Some of the asteroids are missing lines, not sure if it is related to #1.
3. There are times where the picture will jitter in the Y direction. Will try to 'wipe' the y-gain pot and see if the problem persists or not.
4. On the AR board, 1N4001 was burnt to a crisp upon purchase. Have replaced with 1N4007 per expert Andy's advice and seems fine so far.
5. Need to undo the Fuse1 bypass on the power block as previous owner hacked this.
6. Audio hum present but reduced when fiddling with volume control. Either the knob needs to be replaced or I am grounding it when I touch it.
7. Player 1 and Player 2 buttons do not light up
