corky
i have a matsuposhita in a millipede that is currently experiencing vertical collapse. i already did a cap kit and reflowed all ics and any questionable solder joints, but still no luck. whats the next step from here?
change out the vertical output transistors. they are the small black box with three legs transistors mounted to the metal frame in the middle. if that doesn't work I have a good working chassis for 75.00 shipped or you can ship me your's too.
ok, i was able to plug the chassis into another tube and it fires up with full picture. this leads me to believe that my problem is not with the chassis, but with the tube/yoke. how do i go about testing the yoke to see if its bad?
