matsushita tm202 instead of electrohome go7?
Superully
Lauda, Baden-Wuerttemberg, Germany
i have to replace the electrohome go7 monitor on my frogger cabinet and the only spare monitor i have lying around is a (working) matsushita tm202.
however, i don't know how to hook it up because the go7 uses two seperate pins on the chassis for vertical and horizontal sync while the matsushita has only one pin for negative composite sync.
being the electro noob that i am, i have no idea how to hook / wire up that monitor so that i get a picture. is it even possible to use a matsushita instead of an electrohome?
any (valuable) input is appreaciated ... :)
let's add a picture: here's the old electrohome connector on the left with the two sync wires (yellow and white, don't know which one is which sync). on the right is the 6-pin connector of the matsushita monitor.
basically i have to get one negative composite sync signal out of those two wires so that i have 5 uses pins instead of 6 ...
If that is the way your connector came off the frogger the frogger is positive sync and you can't use your matshitua since it only takes neg composite sync. Someone correct me if I am wrong.
if you have the Sega gremlin PCB. look in the manual.
i forget which pin it is but i run mine on a sanyo and its negative synk.
my harness was hacked up so i had to look in the manual to get the rite pin. the one that i was using was on the + synk pin from the old monitor that was in it and the sanyo didn't like it at all. after i changed the wires on the PCB connector it worked fine.
i would look for you but my games are not at my house. all my friends enjoy my games at their houses:-(
Peace
Buffett
trying to send you a pm but it wont let me. it gives me this error message.
Forbidden
You don't have permission to access /private.php on this server.
ill try again later.
Peace
Buffett
yea i got yours but could not reply. it gave me that error code.
i'll try again tonite. your day time:D
Peace
Buffett
