shawnjefferson
I have a pole position upright that has an issue with the monitor at the moment, a Matsushita TM202-G. It's blowing the fuses and R809 is burning up when plugged in. I tested some of the diodes and I think that D802 and D803 might both be bad. I'm getting good voltage, 123v AC or thereabouts.
The issue started when I was working on the power supply. I took it out to do some work, and I think the ground from the monitor may not have been making a good connection when I turned it all back on.
I was wondering if anyone else has seen something similar, and what other parts, if any might be bad in this scenario?
Also, where is the best place to buy replacement fuses? These are supposed to be slow-blow fuses?
