modessitt
I installed a 115v version into an arcade cabinet, as I've done before many times. Of course, now I have a problem.
What I've done (and it's worked in the past) is built a connector that only has 4 wires to the acceptor. 2 wires are for the 115v, and are connected to pins 4 and 20. I've got two wires connected to one of the credit switches on the coin door, and are connected to pins 1 and 16. Pin 1 is the ground wire on the coin switch.
The problem I'm having is that when it powers up, I get two flashes of the red LED, and it will not take bills. 2 flashes means the mech is not enabled. I've tried various dip switch settings for different pulses, credit line, acceptance, sensitivity, etc, and am not getting a change. The only is when it goes to 4 flashes when I take the magazine off.
Any thoughts?
Any thoughts?
