mike11
I have a 2600 and a VFM3........... The 2600 is a newer flashport unit ...... Does anyone have the troubleshooting tree for the led flash codes ??? And also the "coupon" that's filled out and inserted for setup ??? This unit dosent even try to accept anything unless the service button on the back is pushed but I don't have the coupon to fill out and let it read........
I also have a new coinco unit here which dosent run the feed motor when the bill is inserted ...... I cleaned all the optics and made sure they're lined up and nothing just the stacker cycles ...... The vfm had the harness from the controller rub through and short to ground ..... I'm gonna assume it took out the box but I'm not an expert on these things ........ Any input I'd appreciate !!!! I'd like to get one of these up and running
