You could try another bulb, but it could be a defective starter or ballast. While you are at home depot buy a bulb and starter. If those don't work, then it most likely your ballast. I hope this helps.
Arcade Greg
No, it's the same bulb & starter as the rest of the Nintendo cabs in the DK style family.
Just like EVERYTHING on these Nintendo cabs nothing is easy or cheap to find...meaning you will NOT be able to find one at Home Depot or Lowes.
You'll have to order them online from a specialty place.
There are a few but I've gotten mine from topbulb.com
I usually pull the entire fixture and replace it with a $12 15" fixture from Home Depot. Plugs right into the bottom of the cabinet and gives a more full light and looks much better.
