Marquee light bulb , only ends light up .
ScumBum
California
So how can I fix this , the bulb only lights up at the ends , not in the middle and its very dim .
I've seen this with both bad bulbs and bad starters. I'd replace the starter first, since it is cheap, then the bulb if that does not work.
Thanks guys , the bulb I pulled out of another game and it works good , so I know its not the bulb . It must be the starter .
Awesome . Now I know what starter to get .
New site looks good . I used to visit your site alot in the late 90's . It was the best one around back then .
Thanks. I spent a lot of time rewriting it so I could expand on it easier. Hoping to breath a lot more life into it this year.
I had the same issue with one of my bulbs. I put a new bulb in, but did the same thing. Then I replaced the starter and it worked.
