Mario WB T-molding size?
sk8ersublime
Frederick, Maryland
Hey Guys,
I tried searching a bit and I could not find the info I am looking for.
My cab is not at my house right now, so I cant confirm until this weekend, but I wanted to know:
Did the WB come in Plywood and Particle Board? I am pretty sure mine is Plywood.
I wanted to know if the WB used the same size T-molding:
9/16 - Ply
5/8 - Particle board
Again, I would confirm this on my machine, but it about an hour away from me at the shop where Ill be restoring it, so I am trying to get the parts I can in the mean time so I dont have to make a bunch of trips back and forth.
Looks like Ply to me:
Thanks for any info!
That is a plywood cab. When you can see definitive layers (plys) of wood you have a plywood cab. If it were particle board it would not be layered in that fashion. Hope that helps you out.
Yea I was pretty sure it was ply, I only have the pic to go off of. I am guessing that means I need the 9/16 molding. I'll measure tomorrow since I'll have the cab
