Mario Bros white screen
stss95
Illinois
I tried to install my mario bros high score save kit today everything went ok but when i powered it back up i only get a white screen, checked everything like 10 times and same thing. pulled out the high score and put just the original chip back in and same white screen. arggggg. Any thought>?
White screen usually means no input signal on a sanyo. Are you going through an inverter board? If so, try going straight from the Mario Board to the monitor.
where do i check the +5v the machine is all stock, inverter board?
