Marble Madness Questions
thefader
South Dakota
So I have a converted Marble Madness Now.
Ill need Marquee, PCB, and CPO. Also, Mine was converted to a JAMMA game.. The board in this picture, hooked to the left side of the cabinet is missing. What is it, and are they easy to come by?
IIRC it's an AR III or is it II amp and power board. Shouldn't be too hard to find and if you really need to I believe a different style atari amp board can be used in conjunction with a switching power supply.
I have the big ISO at the bottom of the cabinet, but both boards and the harness are gone.. I'd really like to bring this thing back to life..
Know where I could find one?
There is a Jamma switching power supply in the cabinet, what else would I need to use this? They have it wired off of the ISO.
some system 1 games had run off a ar3 and some off a switcher. the picture you provided is running of a ar3. its the board in the back left. You can buy the ar3 and harness from quarterarcade last time i checked.
Yep, those both would be good starts. You'll hopefully get a good MM CP harness when you pick up your kit/panel. It plugs directly into the motherboard for the most part.
