You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
Museum of the Game® & International Arcade Museum® Forums
Custom built Marble Madness 2 arcade machine. Something you don't see every day, not sure I've ever seen an MM2 in any arcade outside of ours so it would be very unique! As the original board set is basically unavailable, it is running this in emulation but it plays GREAT and is a lot of fun. Three joystick setup, as was the case on the original machine I was able to find doing research. Has a 27" LCD screen. On free play. Original machine was a Revolution X 3-player, so that side art and glass is still visible. If you wanted to go the extra effort to change that out it would look pretty spectacular. Local pick up only in Shelbyville, IN. Looking for $1,300 OBO.
