I've been working on my hacked up Mappy cocktail and I've run into an issue. After buying a transformer assembly out of a Super Pac cocktail, I realized that the two games mount the transformer differently… super pac mounts the long way across the suitcase, while the mappy cocktail uses the short sides of the suitcase. However, the transformer picture in the mappy manual shows that it mounts the long way. So was the mappy cocktail the only time they used the shorter mounting variation? Also, rather than a bracket, the whole bottom of the assembly is made to fit the mounting holes. Is there a way to modify the bottom to fit the shorter side or do I need to locate a different bottom?
