Mappy Broken Resistor please help verify
PrairieDillo
Donor 2011, 2024
I was pulling the chips off my Mappy (cleaning the leggs) to try to fix some artifacts around certain sprites and I pushed down on a resistor and cracked it in half so I cant measure it for its rating.
its in the B 1 section of this board
Close up labeled C4???
My old eyes read the resistor as Red Black Red Black Gold
On an online calculator it says 202 ohms
Can anyone confirm this?
In the manual it lists C-4 on the CPU board as .001 MF
OK I am reading the specs on this like you guys are but obviously the broken part is a resistor. I should replace it with a ceramic cap? I mean its oddly clearly a resistor in there currently.
Just got home and looked at my board. It has the same as your board had at location C4
Yes thats the same banding code also... Thanks for the confirmation
Now to scour old PCBs at work for a .001 mf cap
It should not be that hard. Do you not have a PCB at home that is dead and used for solder practice?
Thanks for the help guys! The value was easy enough to find on a random old board at work.
I managed to match a few axial cap values on the board also. Now to retest it when I get home.
I pulled all the eproms and mask roms as well as the 68k chips to clean the legs with contact cleaner and a fiberglass pen to polish the legs till they were shiny.
Mappy back up, cleaning helped fix the artifacts. Now if I can find that RAM module and reburn the HSS roms... With the credit jumper this machine would be done.
I actually did find the unopened RAM module package (ordered from eBay) for the HSS. Now jus need to find two 2764 eproms so that I can burn the HSS ROMS and plop them in!!!!
