MAME input delay / lag....
Buy a J-Pac and you should fix any lag.
Looks promising except: "No special drivers needed. USB drivers are generic Windows."
But it claims to process each input seperately:
"All inputs are completely separate and generate their own interrupt - this is the fastest possible method."
So the hardware looks capable, but I worry about the "generic Windows driver" part. If USB drivers in Windows are a problem, then this might not do it.
I looked at the one on Ultimarc -- I might give this a try. The price doesn't look too bad if it will fix the problem.
Sorry old thread, but I couldn't let it go with the comments on the Lono, missed those before.
First off, the Lono is more than 4 times faster than the fastest advertised rate on the market (the fastest we could find is 125 state changes a second, the Lono blows this away)
Lono integrates into windows as a standard microsoft arcade controller, no special drivers are needed.
Finally cost... It is true that the Lono is $65 dollars, but that is for a four player board, with complete harnessing. If you take any other vendors high quality controller and compare it for a 4 player set up, the Lono is cheaper. If you do the cost per input, we are closer to the costs of Xin-mo boards which are a step back in performance and quality.(We do sell the Xin-mo for 25-30 per 2 player set up also)
I can assure anyone interested, that you will save a significant amount of installation time with the Lono.
The only problem is that we are out temporarily of stock....but in a week a new surprise will hopefully be taking it's place!
My MAME lag issues almost always surrounded the video settings. Changing them to settings that weren't as aggressive or didn't seem as logical actually helped in a few circumstances.
