Makvision M2929 video card recommendations needed!!
I have a Makvision MM2929D4-TS162 CRT SVGA arcade monitor and I'm looking for a video card that would work well with the monitor as I'm having an issue.
It's currently connected to a PC with an onboard graphics driver. The monitor looks great and works well, but every second-ish it flashes a thin vertical line in the lower third on the left. I'm told it's an artifact from the monitor being hooked up to a PC.
I'm sure this is a result of the PC onboard graphics driver as when the monitor is powered but receiving no signal from the computer, the line doesn't flash.
Thanks in advance for the help!
