GuidoTorpedo
Ok, I had a makvision 2929d4g-ts take a dump in one of my fast and furious machines. I have a 2929d1g-62 on the shelf that has a bad tube, I believe. The chassis look the same, but the pin out for the tube socket is different between the two, and I'd have to swap the neck boards. If I swap the neck boards, can I use the one chassis on the other tube?
Mike
Mike
