Makvision 25" tri mode power wiring...
malignantpoodle
Centennial, Colorado
Hey folks. Looking at this item here;
http://na.suzohapp.com/monitors/49305600.htm
I'm wanting to add this to a Neo Geo 4 slot cabinet which is completely stock at the moment. But, I have some concerns over how power is provided to this unit.
First of all, the unit has no power cord and that is a separate purchase. Doing some digging, I found a guy on youtube that had it and the power cord was a standard three prong like a PC uses.
My current monitor and wiring setup has a simple 2 wire molex that is keyed for orientation so it cannot be put in backwards. I want something that would work with that, or at least get some insight on how to make the monitor get power the way the existing one does from the power supply (assume there is no service outlet).
I do not want to run another power cord from the cab which seems ridiculous to me. Anyone have any insight on these? Thanks in advance.
Like I said on the Neo forums you should have a service outlet on your power supply if it is original to the cabinet that you could plug it into since it doesn't need an iso.
the guy on youtube is me. Just put a power strip in the cabinet and be done with it. The power cord is cheap enough through happ to not make the price too high imo.
