FS Parts: Major Havoc PCB & Ikari Warriors kit
Xyla
San Antonio, Texas
I have a tested working Major Havoc PCB, the conversion version. The quad pokey is defective, but it works well enough that if you weren't familiar with the game sounds, you wouldn't know anything was wrong. Most sounds are correct, but there are a few that sound wrong, beeps that play white noise instead, etc. All the music plays correctly.
I swapped in a good quad pokey from my MH machine and all sounds were perfect, so this is easily fixed with a replacement. There are no other issues with this PCB.
I also have a working Ikari Warriors kit: PCB, marquee, bezel, and a populated converted Centuri CP. One of the rotary sticks has a broken tension spring and so is really loose. I was going to replace the spring but I could not figure out how to take the stick apart. The harnesses for the rotary sticks are intact, but the rest of the controls (buttons, etc) will need wiring. The marquee has some significant scratches. The bezel is in good condition but it has a hole cut in the lower right corner which has been covered with a "25 cents per play" sticker.
Major Havoc PCB: sold
Ikari Warriors kit: $140 shipped.
Ikari kit pics...
Props to KLOV'r "scotth" who created this pic ages ago on BYOAC. Has helped many solve the riddle of LS-30 handle removal. :D
Good luck with the sale.
I did try to make a tool like that out of some wire but I was still unable to pop the cap off the stick. I'll leave it to the next owner to wrestle with it.
How wide is the ikari warriors CP?
23 5/8"
If you find yourself in Phoenix soon, and your MH board is still available, I'd like to pop it in my Tempest conversion and see if the PCB is the issue with my machine (jumpy graphics and funky vector lines). If that does the trick, I'd likely buy it off you on the spot. The sounds on mine are good, so I could swap the pokey.
I'm almost 100% certain it is your PCB... I've never seen a vector monitor behave like that on its own, and I don't think it's possible for one to.
I wasn't planning on coming up to Phoenix soon, but I'd like to help you get your machine working. Hmmm...
It would be a great opportunity to also sell me your Gravitar or Pleiades.
Price is now $140 shipped. This is my final price drop before it goes on eBay.
I tried EVERYTHING to get the stupid caps off the joysticks. All the wire and photos in the world won't help me. Whoever buys this is getting the whole control panel and they can deal with it themselves. If I make one more attempt, I'm going to throw this thing against the wall.
