Major Havoc CPL question
kruuth
Georgia
I've managed to get a Major Havoc that is in passable shape, but it;s missing the board and monitor, so basically it's a shell. I'd like to build a new CPL for it. Does anyone know the angles that the original metal was bent at? If now, has anyone built a new control panel for one of these? It'd be nice to have something going in the cab.
Is it a dedicated or is it a Tempest which got converted with the kit? You might have more luck finding info on the Tempest CP or even a used one on Ebay than an actual MH.
I think it's the converted tempest. It looks like a standard arcade cabinet with a spaceship sideart.
There was a factory conversion for Sapce duel that included a replacement control panel. I believe the metal is the same but there are definitely not as many holes. Archer made some replacement CPOs at one point and I know somebody else on here had a replacement CPO made to allow the original Havoc spinner to be used. The Space duel conversion used the original SD harness and an adapter board that allowed you to use the MH board. The board was also modified to allow the use of a Tempest style spinner instead of the roller controller. You can find more info at ionpool.net
