madden help!
The VGA cable is connected to the PC and the monitor.
Might want to check to see if the computer is outputting video by testing it with another monitor.
Or just get back in there and re seat things. With the power off BTW.
And if you go back into the BIOS you can make it so you dont have to manually turn the PC on.
VGA cable was connected to the wrong spot on the pc. I just noticed when I was sending the pics on here. It's working now. Thanks for making me look at this closer
where did you end up moving the VGA cable too?
Onboard video isnt going to render the game correctly/fast enough. You really want video to come from that video card.
The pic shows the correct position. I took the pic before I removed the pc to change the battery. I looked at the back of the pc after making the post and noticed I had reconnected the vga cable next to the white dongle(wrong spot).
I went in and setup all the correct bios now and everything is working.
