Machine Of The Year?
in case its gone the description was lame (He says the phrase "pull up a chair" how the fuck do you do that?) and he wanted $350 for this?????? I don't know the words
That is just too ..............................
Were those pics taken on the set of "Hoarders"? The only thing missing from the shots is a dead cat stuck to the carpeting.
If you look closely, the machine is pretty low to the ground. And the CP area sticks out quite a bit, and looks to have leg room for a chair underneath. So it's probably "designed" for you to pull up a chair.
Also someone beat you to it.
http://forums.arcade-museum.com/showthread.php?t=153129
Judging by the rest of the setting, the nearest chair probably has some fecal remains stuck to it, with cat hair embedded in that.
