M5000/KV700A monitor chassis cleaning?
augusthansen
tallahassee, Florida
What is the best way to clean this badboy? Its in great shape, It is just CAKED with a layer of grime and dirt. I've heard a paintbrush and warm water and preheat the oven and put it in there to dry overnight. But im looking for the SAFEST procedure to keep it working and make it clean. any suggestions would be GREATLY appreciated! thx!
I just use either Simple Green or some other form of cleaner. Most of them if you just spray them on and let them sit for a little bit. Then you can just rinse them off with water (I used a garden hose). Don't worry about baking them (unless you want to). I put mine under a work light and rotated it every once in a while. After that I just let it sit for a couple of days before powering it back up. Seems to work pretty well and the boards I was cleaning looked even worse than the one you are working on. Hope this helps!
