LW3 display issues.
Mr Do
Donor 6 years: 2012-2013, 2015-2016, 2019, 2025
Basking Ridge, New Jersey
Lethal Weapon 3.
The display has some static garbage floating around. But do work and scores and graphics can be seen. Anyone know how to fix?
Thanks.
LW3 dmd
When I bought game 3 months ago I don't remember the distortion. But now it is noticable. I did reseat connection and thought It went away. Now staic/distortion is back week later. It has new rottendog cpu by the way.
A little more info-
What revision CPU (ROM) are you running?
What display revision (ROM) are you running?
I have seen this behavior with various ROM incompatabilities. Also, is your display rom a single rom or double rom on the display driver board? The newer style single roms can have issues as well (Went through it myself).
Merely a guess at this point, but if you reseated the ribbon cable and the issue went away for a bit, you may have a flaky ribbon cable. Those do go bad from time to time.
LW3 dmd
I have to look at roms tomorrow. Where can I get a new ribbon cable?
