I'm going off memory, but I replaced a target in both banks with them in the machine. You have to remove a bar from the back, if I remember correctly it is held in place with two bolts. Remove the spring using needle nose pliers. Replace the target and reinstall everything. The hardest part is removing and replacing the spring.
