lunar thruster resistance question.
Alpha-tron
Donor 2011, 2019
Rowland Heights, California
Since my lunar lander is out on loan, I don't have an answer for this question off hand and I don't recall cause my mind is elsewhere currently.
The question is
In test mode, what is low low and high readings of your Thruster ?
Thanks in advance..
Can I borrow your lunar lander when it gets returned to you?
That should be close enough... I'm pretty sure Lunar Lander calibrates itself anyway (when you first turn it on, you'll notice that you have full thrust until you move the thruster, and it keeps track of the minimum and maximum value and divides the thrust evenly across it).
Are you saying in the game you're not getting full thrust, or you're just worried that you're not getting to AA in self test?
DogP
Nevermind.
