ZEN
***SOLD ON EBAY***
I hate to do this, but I am selling my Lunar Lander with a nice working monitor (V2000 with adapter harness), recently repaired boardset by a fellow klovr and its spot on, completely sanblasted and restored control panel, the coin door was stripped, sandblasted and put back together. Original cabinet with LL serial number, side art is nice and original, cabinet is pretty damn solid, has a few scuffs on sideart but they may be able to be removed, not in the paint or screened art.
The cab has some slight raising around the top, not swelling, just raised bubble a little. I cant see it in my dark arcade room, but under bright flourescent light you can. EDIT** I repaired and replaced the lamps in the mission select board and it works fine now.
-The bad, if you can consider it bad, I have new Tmolding, but the channel holds it a little loosely on top so I have to get that sorted, I may just let the new owner do this as I dont want to glue but others may be okay with this.
Why am I selling, well, I just found one of my grails (no need to explain this as many of you would think im nuts) and I had tough choices to make on what goes, and unfortunately its got to be the LL.
Noted** - you can have this with the working v2000, or the original G05-801 which needs the HV coupler done, I attempted and did not get it right, but easy $25 fix, defelction board gets chatter, tube is good.
PHOTOBUCKET LINK FOR SOME PICS: http://s1118.photobucket.com/albums/k603/jrzen311/lunar lander/
