ScumBum
I'm getting only 42 volts to the marquee light in my Galaga , how do I fix this ?
And you took this reading where?
Unplug the machine from the wall. Pull out the half amp fuse that runs the marquee. Now set your meter to the lowest resistance scale and measure the resistance of the fuse. Should be less than 1 ohm. Now while the fuse is out of the fuseholder, physically check the fuse clips for signs of tarnishing. Now squeeze the clips together a little closer so the clips grip the fuse better.
Ok thanks , the fuse is brand new , I replaced all of them in the game . The fuse clips from what I could see , it was pretty dark , they looked tarnished and rusty . Whats the best way of cleaning them ?
