ok I have a really nice huo lotr that I got, but it has a right lower flipper problem
when I got it, q 16, on driver board was fried, (lower right flipper drive )
q 16, and the flipper coil had been replaced by the last repair guy
I replaced q 16, again, and it blew the fuse right away and fried q 16 again
the coil was wired right, and looks tests good
but looks like a heavy duty lotr coil
just to be on the safe side I sent the driver board off, got it tested and repaired, only thing wrong they found was q 16, but I know if I plug it in, it will likely blow the fuse and q 16 again,
what else can cause this? I plan to get a new coil, just to be safe, but suspect it will still do the same, ?
this is a huo game with no one monkeying in it, could it be a kinked wire or short in the wiring cause this?
or?
or?
