Lost World Tilt Problem
Rudy
Blakeslee, Pennsylvania
I am considering purchasing a Bally's Lost World Machine. According to the seller, everything works except the machine is reading "tilt" all the time. How hard/expensive would this be to fix?
I am a newbie to the pinball ownership/repair/restoration, so any guidance will be greatly appreciated!
Thanks!!
Easiest thing would be just to check the tilt mechs. Probably a slam switch on the door, maybe another slam switch somewhere on the underside of the playfield. One plumb-bob type tilt probably somewhere on the left front inside of the cabinet, and maybe a ball-roller tilt around the same area.
Any of those switches being closed when they're not supposed to be could cause that issue. If those switches aren't at fault, I'm at a loss, as diagnosing PCB level issues is a bit beyond my capacity.
