lost recoil on rifle em game, any help?
justifier112
Donor 2020
bloomington, Minnesota
the other day recoil worked on my flying saucer,
today nothing, any help? i changed a fuse on the back door but still nothing,
all wires look good and the recoil slides easy by hand and i just cant figure it out
thanks
matt
yes there is a coil, the coils moves in its barcket freely,
i put a amp meter on it and at idle it has close to 2 amps, then pull the trigger it
goes up to 3 amps, but no recoil.
im stuck and want to go thru all my options before i call a 60 an hour tech
thanks
matt
What you want to do first is turn the machine off then using your meter measure the resistance of the coil.It sounds like the coil is"open" meaning it won't work.When you measure the resistance you should NOT get an infinite reading,if you do,you will need to replace the coil.
yea i have seen them also, i have the original schematic, the schematic does tell me the coil number, (dummy me) and i didnt think one bit until i seen your post, thanks for smacking me!!
