I have no idea what I did. I've been playing around with a tube swap with a WGk4900. I thought I was successful, but had some curl. I was reading about the sync issues that can sometimes cause it, so I was working on those. While I was trying different combinations of jumpers, I would unplug the power to the monitor, and then plug it back in. My molex connector isn't great, so sometimes I would lose the connection. Well, after doing this several times, I all of the sudden just flat out lost power to the monitor. Couldn't get any neck glow or anything. After this set back, I just decided to pack it in for the day figuring I fried something. I went to plug back everything into my Journey, and now that G07 doesn't work
Can't get neck glow there either. I have power to the entire cab, and I checked all of the fuses both visually and with my multimeter. When I plug my multimeter into the white and black monitor power wires, it reads 120v. Thinking that maybe I got some sort of burn inside the female end of the connectors, I scraped around with a tiny screw driver, but that did nothing. How does any of this make sense? I'm going to move another cab and see if I can use that power supply to work. Suggestions in the mean time? Thanks.
