bradp56
Ok so I FINALLY picked up my first Tron yesterday. Everything worked fine when I got it and when I moved it everything seemed in tact. When I plugged it in at home everything was fine, I played this for a while then all of a sudden the sound started going out I would hear popping noises and it would work for a little then go out then popping noises.
My question is, is there anything I should look for being loose or will I need to start replacing parts. I noticed on the side of the cabinet there is a small pcb with an input and an output that looks like it connects to the speakers.
Thanks in advance.
Thanks in advance.
