Looking for Vs. Unisystem PCB/Wiring Harness
drummerjosh1984
Missouri
I am looking for The Vs. Unisystem PCB. I would also like to get ahold of the wiring harness as well. PM me if you have one available.
if you are planning on converting a non nintendo cab to a vs unisystem, I would recommend mikesarcade's vs to jamma adapter instead of using a real nintendo vs harness.
a real nintendo harness would only plug into a nintend power supply, and it would output nintendo standard inverted video and unamplified sound.
not to say it can't be done, but the vs to jamma adapter is the easier and probably cheaper way.
and since I just looked up ajax to find that it is already jamma. get the adapter.
I'm a pretty huge noob so I appreciate all the help I've received on this site. When it comes to putting something together I'm handy. But without everyone's knowledge I would have ended up with stuff I didn't need.
To answer the other question, i got a cab i could put it in and rotate the monitor. Or I was considering building a cab to put it in.
you know i have no idea. it has to be jamma adaptable. I am still waiting on some pm's back from 2 individuals so i am still looking
I think it will if side 1 is the one that is used in a single game setup. The JAMMA adapter you are getting should work fine with it,
Maybe some of the VS specialists will tell us for sure.
