Looking for Megatouch MAXX Ruby 2 DVD or hard drive chd image
pun84
New Jersey
Does anyone have a copy of the DVD to reload the hard drive for a Ruby 2? I contacted merit and they said they no longer have the dvd's or hard drive, which leaves me screwed. :(
The backup CHD image I have of the drive also seems to be corrupted, it won't save the touchscreen settings and such when I flip up DS6 for hardware detect.
thanks
Is that the only problem with it ?
So it will calibrate but then not hold the calibration ?
Could be the touchscreen controller is why I ask.
Nah, whats happening is the touchscreen wont work at all. However I know for a fact its working because I hooked it up to two other machines, controller and touchscreen together.
I even changed the motherboard/riser board with another and the same issue happens. Something is going wrong with the software on the hard drive, its as if it wont recognize the touchscreen on normal start up. If I reset the configuration, it says detecting touch screen just fine with no errors, but after it resets to 'update the configuration' it seems to forget tat it found the touchscreen. I am guessing bad sectors on the hard drive
