Looking for Marquee Fixture for Namco Class of 1981
Andy Hoffman
Donor 2012
DeBary, Florida
I scored a Class of 1981 Ms Pac/Galaga a little while back, and the marquee light does not work. I have tried a new ballast and new bulbs with no luck. I traced the wire for the fixture to the back of the cab, and found a male/female plug. There was a part number on the plug, however searching that part number did not yield any results. Does anyone know where I can find a new fixture that I can plug in? I would much rather do plug and play than any wire cutting/splicing. Thanks.
If I can not locate one with a plug already on it, that will be my next option- and a good one. Thanks.
I did try a new starter, but had no luck with it. I am going to pull the fixture out and see if there is anything else obviously wrong with it. I find it odd that the new starter (ballast) and bulb did not remedy it.
did it ever work? is everything connected? On my mortal kombat i had to replace both ends of it to get it to work...im not sure what you call them but the part that each end goes into. real cheap and easy to fix.
I thought of one more thing before I take it out to inspect it. I also have the DK 2005 which has the same internals. I am going to try the bulb and ballast in that cab to see if somehow I got two duds. Doubtful, but to rule it out I am going to try anyway.
