If you cant find one you can just add the 3 pins into the original 36 pin housing. They are .063 pins, just put 3 pins on 3 wires and push into the 36 pin connector at pin 17,21 & 25 and run them to the 3 pin plug on the annunciator board . I found this info on the Dragon's Lair Projects Archives
http://www.d-l-p.com/community/foru...essageID=49137&Archive=Yes&Keywords=space+ace
Text with info
On A DL/SA conversion harness, The connections
for the Skill Level Buttons go to a 3 pin
connector which connects from pins 17,21,& 25
on the 36 pin molex plug on the harness to the
SA annunciator board. There is another small set of
wires going from the 9 pin connection on the conversion
annunciator board to the Skill level select buttons.The
scoreboard ribbon cable also goes from the main pcb to
the annunciator board and then an additional ribbon
cable connects from the annunciator board too the led
scoreboard.On a dedicated Space Ace Wiring harness,
the control panel connector has 12 pins instead of the
typical 9 pin connector. Hope this helps.
